Instrument Cluster Problems
The cluster functions normally all summer but once the outside temp goes below 50 degrees the overheat icon on the center display will come on for several minutes when I start the car. I don't think this is a temp sensor problem because the date and time on the cluster will reset about the same time. I think this is an issue with an intermittent connection on the cluster. Before I ship the cluster off to Module Master to be rebuild I wanted to see if anyone has had the same problem and what they did to fix it.
Battery
Mine is strictly temperature related. It is fine all summer and when fall comes and the temp gets below 50 the overheat icon pops up almost every time I start the car and the date and time will reset several times over the winter.
I'll start with the easy things first. I'll check the battery cables and voltage. I was thinking about taking the instrument cluster out far enough to get at the connections and verify that they are properly seated.
Thanks again.
Thanks again.
