pulled a code
Old 10-25-2005, 12:15 AM
tdctt's Avatar
Default pulled a code
well i jus purchase my tt two weeks ago and i install injen intake and a 007 dv after that now i pulled a code it read fuel and air metering any clue of what this is?
Old 10-26-2005, 04:23 AM
VelociTT's Avatar
Default RE: pulled a code
bump to try to get you a response. perhaps your MAF went bad?? how many miles? do you have an oiled air filter (k&n or something similar?) those will screw up your mass air flow sensor if they are over oiled. if you need a temperary fix for that, you can unplug your maf & the car will automatically go into speed density mode or something like that. this will put up a check engine light though, but the car will run better (if it runs crappy now)
jjhasmadskillz
B7 Models
06-24-2013 01:29 PM
sdboarder84
02-23-2008 11:04 AM
munkee
08-23-2007 08:46 PM
LouMan
11-08-2006 09:02 PM
rayveedub
10-24-2006 11:52 PM
Quick Reply: pulled a code
