Replaced my fuel filter now my car wont start..help
Old 10-16-2009, 12:14 AM
SmoothTT's Avatar
Member
Default Replaced my fuel filter now my car wont start..help
Yesterday I replaced my fuel filter n when I first turned the car on it started n it n drove fine. Today my car does not want to turn on, but it cranks but it won't start n yes I do have gas.. Helppp
2000 audi ttq
Old 10-16-2009, 11:14 AM
cincyTT's Avatar
I'm make believe
if you installed to filter the correct direction, its not the problem. Have you checked the battery for a charge and it has a good clean ground?
Old 10-16-2009, 12:06 PM
SmoothTT's Avatar
Member
the arrow on the filter is suppose to point towards the front of the car right?
well now my battery seems to be dying since i been trying to turn the car over..but where can i check for the ground?
Old 10-16-2009, 12:47 PM
cincyTT's Avatar
I'm make believe
The main ground is connected to the starter. Just make sure all the connections are clean
Old 10-17-2009, 06:40 PM
SmoothTT's Avatar
Member
everything is good, and i also had a mechanic look at it and he informed me that the fuel is reaching the engine and that it has nothing to do with my fuel lines or filter..
any help
Old 10-18-2009, 09:49 AM
achTTung's Avatar
so you have wet plugs?
Need 3 things for an engine to run. Maybe 4. Fuel, Air, Ignition source. (alternate #4 would be ignition timing, but that still sorta falls under #3).
If your getting fuel, you can check that off the list. Next check for spark, because unless you car is in outer space, its most likely getting air.
Might not hurt to reset the ECU/clear codes. I unplugged my injectors once and cranked the car over a bunch of times to re-lube cylinders after doing a head gasket. When I plugged the injectors back in, the car wouldn't start. Wouldnt inject until I had cleared codes. Totally didn't expect that. Sometimes the ECU just isn't sure whats up.
skihigh2299
09-25-2015 12:09 AM
pistol pete
11-08-2011 09:10 AM
bcan
04-08-2010 12:17 PM
Rudyu
09-02-2009 10:23 AM
02A418T
08-21-2007 09:43 PM
Quick Reply: Replaced my fuel filter now my car wont start..help
