Shaking from front driver side. !!
Hey guys. I have a mk1 225 tt, and recently noticed on my 15 minute commute to work a slightly shaking feeling coming from my driver side front wheel. From what I have read it seems to be a wheel bearing? Although i'm not very mechanically inclined, so I really have no clue. Anyone know the solution or fixed a similar problem? Also it's mainly felt between 55-70, not much at other speeds
Thanks
Thanks
If your wheels are weighted with the tape-on weights, you might see a fresh/clean spot where the weight used to be, but you can "see" an imbalance ....just gotta get it re-balanced.
Best thing is to go to your local tire shop, pull the wheel, and just have it re-balanced.
Your description of shaking in a particular speed range is a usual sign of the need for rebalance.
slideitsidewayz
11-23-2008 05:32 PM
slideitsidewayz
11-23-2008 05:31 PM
