AudiForums.com
Go Back   AudiForums.com > Audi Models > Audi TT
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 04-26-2005, 07:25 PM
Default Why is my battery dead?
Okay, I have this strange problem that if I don't drive my car for about 3 - 4 days the battery needs to be recharged. It's fine if I drive it every day and even if I don't drive it for one day but whenever I let it sit for 3 days or more the TT wont start. Battery totally dead.
I even bought a brand new Optima Red Top battery which wasn't cheap and it still does it. So I know it isn't the battery. And the alternator does charge the battery or I wouldn't be driving it almost every day without problems. What else could cause this slow drain on the system?
Any ideas?
No, I don't have a warranty on the car so taking it to the dealer will be my very last resort.
Thanks for any help or thougths on the matter
Tom in INDY
__________________
Tom in Indy
'01 225Hp TT Silver Coupe
Old 04-26-2005, 07:45 PM
Default RE: Why is my battery dead?
ttt
__________________
Tom in Indy
Old 04-29-2005, 10:44 PM
I'm having the same problem. I've been driving my car and I don't have any problems, so it's not the alternator. I thought it was the battery. I have, in the past, left the car for all of 15 minutes and then returned to discover that it won't start. Won't even turn over. All I get is this clicking sound as I turn the ignition. Not even enough juice to turn over the engine. If I get a jump, I'm good until the next time....This is becoming really annoying.
When the engine turns over, it seems to really labor before it catches. It can't be the sparks because the battery would be dead. I notice that when I'm starting the car, the battery indicator dives down to almost nothing before the engine turns over and finally fires.
I've read a couple of posts and I'm now hesitant about replacing a bunch of perfectly good parts to sort out the problem. Neither am I comfortable taking it to a mechanic, so he can conduct a fishing exhibition. Any suggestions??
J.
Old 04-30-2005, 06:23 AM
James..not sure if you've replaced your battery, but if you haven't....do it. I had the same problem and it was because the battery just wouldn't hold a charge for long. Once it's started and the alternator is running, it kept the battery charged. If I left it for longer than a few hours, I needed a jump. Replacing the battery solved that problem.
Tom, sounds like you've replaced your battery. No advice there. Good luck.
__________________
'98 A4 Avant Quattro 2.8 V6 30v
Stock
Dented roof
Scratches
Non-functioning sunroof
Non-functioning cruise control
Flaky LCD
Old 05-03-2005, 05:33 PM
AWDaholic's Avatar
Points: 32,648, Level: 100
Points: 32,648, Level: 100 Points: 32,648, Level: 100 Points: 32,648, Level: 100
Level up: 0%, 0 Points needed
Level up: 0% Level up: 0% Level up: 0%
Daily Activity: 8.9%
Daily Activity: 8.9% Daily Activity: 8.9% Daily Activity: 8.9%
All of you guyzz symptoms sound like there is some kinda problem with your respective charging systems. The simplest, and least expensive test of your charging system is to disconnect th ebattery while the vehicle is running. A properly functioning charging system will sustain the motor running, obviously, since your car certainly doesn't run off of the battery. If your car does not run when disconnected from the battery you have a problem with your charging system. A bad connection somewhere. A bad alternator. A surly elf (they're responsible for carrying the electrical charge from the fahrvergnugen to the backbahnhinternroller), or something along those lines.
If it is the charging system I'd start with thouroughly inspecting all connectione to and from your alternators, along with the wires. It doesn't cost anything to look for yourself and you might accidentally discover where the problem lies. If ANY of teh connections are dirty or corroded, CLEAN them. A wire brush works best, AND ensures that you'll scrape your knuckles, possibly drawing blood in the process. Don't worry, it builds character. If any the the insulation on any of the wires leading to/from your alternator looks melted or singhed you might want to consider a trip to the Stealer. Same holds true if it's the charging system, but there are no OBVIOUS problems.
Have fun!
__________________
~ Jazz
Quote:
Originally Posted by CCA4 View Post
if i could punch you via the internet i would.
You're so hosed that the concept of hosed has turned in on itself and formed a hosed paradox that threatens to destroy the very hosed universe. ~Cracked.com
Reply
Tags
28, a3, audi, battery, charge, charging, dead, dies, drain, driving, fast, indicator, it, problems, replacing, start, symptoms, timing, tt, turn, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
