Window has a mind of its own
So my driver side window will lower and raise on its own instead of when i open/shut my door. I'll be driving down the road and it will lower when i hit a bump or just randomly. If I hit my door with my hand it will raise back up. Also i cant lock my car because it will lower after i lock it and set off my alarm. Is there a sensor that I can change out or what? its kind of annoying. Thanks
Have you checked the sensor for open/closed door? It should be somewhere by the hinges. This sensor recognizes when the door is opened, so the window lowers. Then recognizes when the door is closed and the window raises. If it's faulty, it could be sending mixed signals to the computer.
I did a quick google search. Turns out the sensor is inside the door, but apparently it is quite easy to take apart.
The Mk1 Audi TT Enthusiast Guide: Door sensor fix - DIY
That guide talks about buying/using a non OEM switch, but I'm sure you can purchase a new one from Audi for relatively cheap.
Now, I'm assuming that you are talking about the window lowering and raising just that little bit which is supposed to happen when you open/close the door. If the window is raising and lowering all the way down/up, then this is a completely different issue.
JDCrowe
04-20-2006 11:00 AM
