1996 A4 Sunroof Stuck CLOSED
Old 03-21-2008, 01:42 PM
Julie's Avatar
Default 1996 A4 Sunroof Stuck CLOSED
I've read several posts about sunroof being stuck open or in partial open/closed position. Mine is stuck closed and there is NO noise of any sort when I attempt to open it. I've found the manual crank spot; just wondering since there is no noise, is it most likely the motor? sorry if this topic has been covered, I'm new to the group.
Old 03-21-2008, 05:18 PM
ImTheDevil's Avatar
Default RE: 1996 A4 Sunroof Stuck CLOSED
I'm assuming that you checked the fuse for the sunroof (swap another one in, don't rely just on eyeballing the fuse - it could blow potentially in a way that you don't notice it). If that's not it, maybe crank it open by hand and inspect the rails to see if something came loose, or off. Or it could be that the motor is blown, although I don't think I've ever seen anyone else post that (not that it couldn't happen).
Old 06-12-2008, 11:20 PM
flyromeo3's Avatar
m/b in reviving this thread but would anyone know how to replace the sunroof motor?
Headliner has to come down?
thanks
Old 06-12-2008, 11:42 PM
JValentine13's Avatar
Im guessing that the whole headliner has to come down. i know you have to do it with bmw's..
Old 06-13-2008, 12:10 AM
audi_n00b's Avatar
At least its not open.
JavanT
10-25-2013 03:12 PM
adsquare
03-07-2010 08:14 PM
mypreludeisred
04-06-2009 08:26 PM
DCA3
09-13-2007 06:25 PM
Quick Reply: 1996 A4 Sunroof Stuck CLOSED
