1998 A4 Quattro 1.8t misfiring CEL need HELP
Old 07-18-2012, 09:17 PM
mattwaugh's Avatar
Default 1998 A4 Quattro 1.8t misfiring CEL need HELP
My car is misfiring and CEL among handfull of other problems an i need to know where to begin.
Old 07-18-2012, 10:17 PM
redline380's Avatar
Legal Moderator
begin with more information. which cylinder(s), how bad, how often, ect... most of the time its ignition control module or coil packs. also, spark plugs will do it.
Old 07-19-2012, 12:34 AM
mattwaugh's Avatar
anyone feel free to chime in. i would like this thread to live long.
Old 07-19-2012, 12:50 AM
redline380's Avatar
Legal Moderator
if you want people to chime in, like me, you need to provide more information. im sorry you have misfires, but theres not a thing in the world i can say about it until you give me what i need to know. it could literally be something as simple as a spark plug to as complicated as a burnt ecu or a shot piston ring. I, or anyone else for that matter, cannot help unless you spill the beans on exactly what is happening.
Old 07-19-2012, 12:55 AM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
The most helpful thing would be to scan for codes, that will give us guidance. Is your check engine light solid or flashing? Does the car misfire at partial throttle? Only under full load?
Old 07-19-2012, 12:57 AM
Tech Guru double team.
And mattwaugh, posting additional threads will not help us get you sorted any quicker. Try to keep it to one thread please.
Old 07-19-2012, 01:47 AM
mattwaugh's Avatar
The CEL is solid all the time and it flashes only when the engine is under stressful situations. It seems to misfire between 2500 and 4500rpm while at greater than 50% throttle.
Old 07-19-2012, 02:40 AM
As you've probably figured out, the flashing occurs when the engine is misfiring. Either take the car to a shop and have the codes scanned or buy a VAGCOM cable on ebay for $10 and scan the codes yourself with VCDS Lite.
Once you have the codes, we can start to figure out the solution.
(I like that you put "misfiring" in your signature .)
Old 07-19-2012, 03:18 AM
DanaB6's Avatar
Also don't drive if your check engine is misfiring, your gonna burn your cat.
Old 03-25-2013, 08:40 PM
fowler12's Avatar
Is the vcds lite free or is there other software at no charge? Thanks
aeanderson84
B7 Models
11-27-2013 07:54 PM
soodiliboo
09-16-2013 03:28 PM
Protype78
05-20-2012 01:56 PM
IggleGreen
07-04-2011 09:08 AM
rodrigueza7
11-10-2005 10:33 PM
Quick Reply: 1998 A4 Quattro 1.8t misfiring CEL need HELP
