AudiForums.com
Go Back   AudiForums.com > Audi Models > Audi A4 > B5 Models
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 04-04-2011, 01:03 AM
Points: 2,713, Level: 31
Points: 2,713, Level: 31 Points: 2,713, Level: 31 Points: 2,713, Level: 31
Level up: 76%, 37 Points needed
Level up: 76% Level up: 76% Level up: 76%
Daily Activity: 2.6%
Daily Activity: 2.6% Daily Activity: 2.6% Daily Activity: 2.6%
Default 2001 a4 1.8t starting problems
ok so when i bought my car the P.O told me that he just replaced the fuel pump and it doesnt start the first time because it needs to build pressure.... and my guess is that he didn't actually replace the fuel pump, what happens is ill turn my key and it will turn over but not start up until the second or third time. could it possibly be a fuel pump relay? or maybe fpr? also should i hear the fuel pump turn on when i turn the car on?
Old 04-04-2011, 01:12 AM
Andrew149's Avatar
Andrewbenson149 Andrew149bens Andrewbens
Points: 4,045, Level: 40
Points: 4,045, Level: 40 Points: 4,045, Level: 40 Points: 4,045, Level: 40
Level up: 48%, 105 Points needed
Level up: 48% Level up: 48% Level up: 48%
Daily Activity: 8.7%
Daily Activity: 8.7% Daily Activity: 8.7% Daily Activity: 8.7%
Send a message via AIM to Andrew149 Send a message via MSN to Andrew149 Send a message via Skype™ to Andrew149
Quote:
that's a lie etheir the fuel pump work's or it doesnt. now i would think its somthing else have the timing belt spark plugs air filter battery and all that stuff been changed out or check on recently?
__________________
2005, Mk4, GTI, 5peed, 1.8T,ebach coilovers, k&n air-filter, Billy-boat 2.5i DP mangaflow exhaust, sachs clutch, BBS rims, apr r1 dv, boost gauge, %35 tinted windows, Stage 1 dog-bone, Shifter bushings, Apr TIP And Evans badd A$$ tune from Absolute. 225WHP
Old 04-04-2011, 01:18 AM
yeah i just recently cleaned the air filter but its a K&N and im not sure about the timing belt or spark plugs, but if they were bad wouldnt it not turn over at all? and it runs perfect after i get it started, i feel like sometimes it starts right up when i have over a half tank of gas aswell
Old 04-04-2011, 01:35 AM
There's a switch that is found on the clutch. A simple switch that is a safety device to ensure that the clutch is depressed before attempting to start the vehicle.
__________________
android phone
China Wholesale
Old 04-04-2011, 04:04 PM
okay i changed all the spark plugs today and did the coolant temp sensor, just because i needed to. its not the clutch switch because it will crank just not turn over the first time
Old 04-04-2011, 05:19 PM
macpyro2's Avatar
Send a message via AIM to macpyro2
Do you smell gas fumes or see a puddle after you park under the fuel pump?
__________________
99 A4 1.8t
Old 04-04-2011, 10:50 PM
no i havent noticed any puddles and i fee like i would notice my gas disappearing lol. i know there is a fuel level sender or something like that could that be it?
Old 04-05-2011, 06:11 PM
okay so after doing some more searching in the engine bay i have noticed something, i had a 1997 a4 1.8t before this one (2001 a4 1.8t) and i remember there being an ignition control module on top of the intake box. There isnt one on this car.... the plate and screw holes where is goes is there but no module. Is that how it is supposed to be or is it missing? PLEASE GIVE ME SOME ANSWERS!!!!!!
Old 04-05-2011, 08:00 PM
an 01 doesnt use an ignition control module, if i were you id question fuel pressure, reason being it sounds like your having to prime the system before starting and its not building enough pressure for the injectors, so maybe a fpr
Old 04-06-2011, 11:48 PM
Is there any way to test that?
Reply
Tags
04, 18t, 2001, a4, audi, b5, filter, fuel, problems, pump, relay, start, starting, symptoms, tur, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
