AEB coil pack upgrade opinion
I'm thinking of upgrading my coil packs but looking around i got options. Which options do you favor , some id have to cut and some I wont have to. Reason why im looking is because misfires/stumbles when i hit around 11psi boost but still kinda pulls ahead.
AEB to ATW
Soruce: 1998 Volkswagen Passat 1.8T AEB - ICM DELETE DIY
Or AEB to TFSI 2.0T
soruce: AEB engine 2.0T coilpack upgrade with INA adapter plates and 034 ICM delete kit
another link for AEB to 2.0T conversion but listed better
http://www.audizine.com/forum/showth...ICM-Delete-***
AEB to ATW
Or AEB to TFSI 2.0T
Did you actually diagnose it to faulty coil packs? Throwing money and parts at misfires isn't a very good way of finding the problem. I spent months trying to track down misfires on my A6. The first thing the mechanic did was change the coil packs, and it solved nothing. I eventually tracked it down to a combination of 3 things, none of which were ignition-related.
To the OP: deleting the ICM is an excellent option. I did it as a preventative measure. My old ICM and AEB coilpacks are still in great shape. To answer your question: it depends how much you're willing to spend. I think I paid $50 for a harness from ECS, and another $20 on shrink tubing. My ICM delete isn't as clean as the 034 or INA options but it was a lot cheaper.
Currently I've got ATW bolt-down coilpacks and haven't had any issues, running NGK BKR7E plugs @ 0.028" gap. Soon I plan to upgrade to 2.0T coilpacks with either INA or 034 adapters, though, so I can run a gap of about 0.040".
I got misfire in cyclinder 3 moved coil around and it followed the coil , i checked it first but i just didnt say it lol. But yea the newer fsi 2.0t sounds pretty good from what i read. Bigger gap , runs smoother, idleing, and some say improved mpg if you care about that stuff lol..
AEB coilpacks and ICM are a very common source of misfires, and are unnecessarily expensive to replace. We often have to throw parts ($$$) at our cars to diagnose issues... recently I dropped probably $600+ just on parts to diagnose a somewhat minor issue on my car, none of which actually fixed the problem. But now my car's got lots of new parts
my question is??? is the Wiring/pinout for the ATW coil pigtail and 2.0tfsi coil pigtail the same then? I know you bought your harness but maybe thought u would know. Cause i got a harness from an AWM motor and the coil pack pigtail from this motor looks the same as ATW and 2.0tfsi coil pigtail.
The reason i ask is because im thinking of using this AWM (2002 passat) harness i got to do the coil pack conversion. I havent seen a wire diagram of this AWM coil yet but im waiting for this e-mail to view it lol.
so since you did the conversion to ATW already. You can upgrade to the 2.0tfsi coil packs with just the adapter plate ?????
4 of these:
Audi Parts - genuinevwaudiparts.com
And these:
FSI Coil Adapter, 1.8T/2.7T/4.2L 5V - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen
They are all compatible 4-pin connectors
That's right! Today/tomorrow I'm receiving these:
4 of these:
And these:
4 of these:
And these:
Thanks
I hate to sound like an idiot, but I'm trying to get my head around this. I have a 2001 A4, 1.8 T, AWM motor. Does this mean that I can upgrade to the 2.0 coil packs simply by buying the coil packs and the adapter plates? I hope the answer is yes, because I'm sick and tired of replacing the regular coil packs.
Thanks
Thanks
kraylon
07-29-2009 12:19 AM
