Auxillary fan fuse and relay location
I have a 2000 A4 2.8 quattro. I had a bad auxillary fan. The bearings were screaming for a month. Before I got a new one it just stopped working. Hooked in the new on and it isnt powering on. So I know it with has a blown fuse or relay. I have heard about a 40amp fuse. Can you please tell me the location of this? Its not in the fuse panel on the left side of the dash. Also tell me the location of the relays?
Thanks
Thanks
I asked sever repair shops and they ensured me that there was only a relay, not so. There is a fuse, it is a big orange one. It is located on the drivers side, there is a black panel you must remove, it can be a little tricky. There are a couple of bolts and the panel will come loose, if you look up in there you will see the orange fuse. I am not sure on the location of the relays.
