Can I remove CV boot without removing the driveshaft?
Old 04-25-2010, 09:10 AM
Nevalite's Avatar
Default Can I remove CV boot without removing the driveshaft?
Can I remove CV boot without removing the driveshaft? Just trying to replace the outer cv boot, dont want to remove the driveshaft. Possible?
Old 04-25-2010, 09:39 AM
hiwords's Avatar
the boot slides over that shaft so you def need to take the shaft out the hub side.
Old 04-25-2010, 10:59 AM
dragonrage's Avatar
There's this but I dunno how well it works: http://www.ecstuning.com/Audi-B5_A4-...oot/ES1899405/
Old 04-25-2010, 12:00 PM
FASTER's Avatar
Tech Slut
I could swear I've seen ones that like zip or button up. I'd never use them tho. Do you have s ripped boot or what?
Old 04-25-2010, 12:22 PM
Nevalite's Avatar
Yeah my boot is ripped and all the grease is coming out.
The knuckle assembly is off right now. Could I not just break the clamps of the old boot, cut the boot off, then drive off the outer end of the driveshaft? Does the outer end come off? If it comes of I can easily do this without removing it from the tranny...
Thoughts?
Old 04-25-2010, 12:39 PM
dragonrage's Avatar
The outer joint comes off easily. You just thread the old axle bolt back into it directly (with no knuckle there) and it will push off. Clean the joint and the axle thoroughly. Take off old boot, put on new boot, pack CV grease, get joint on as much as you can by hand, thread old axle bolt (if it's not f-ed up) most but not all of the way into the joint, hold it straight and hammer on the joint using the bolt. Do not hit it super hard but be pretty firm. When you reassemble, use the new axle bolt. If you hear "ssssss" air sounds then your inner boot is ripped, too.
There's a full guide on audidiy... just ignore how it recommends to remove the whole half-shaft. You don't need to.
Old 04-25-2010, 12:46 PM
auditech79's Avatar
I use either a gear puller or slide hammer, then the cv joint pulls right off the shaft. You can buy those boots that bolt together, but they always leak.
Old 04-25-2010, 12:51 PM
dragonrage's Avatar
I was thinking about the slide hammer idea, but does threading the axle bolt back on not work for you? I've only tried it twice now but it's worked both times. Maybe you've had less good luck?
Old 04-25-2010, 01:21 PM
Nevalite's Avatar
Sweet deal, ty dragonrage.
Old 08-22-2014, 01:10 PM
Brityank's Avatar
Hey, Dragonrage! I know this thread is 4 years old, but I just wanted to say thank you for the axle bolt tip. You just saved me a lot of head scratching and extra work.
Jonesz0003
03-15-2022 12:16 AM
DHarrienger
06-07-2012 02:17 PM
justinm001
02-22-2010 10:45 PM
96audia4
04-25-2009 05:02 PM
Quick Reply: Can I remove CV boot without removing the driveshaft?
