Center driveshaft question..
My carrier bearing is shot and I got a line on a low mileage center driveshaft out of an 01 1.8tqm. Anyone knkw if this will bolt up to my 96 2.8qm? I believe the driveshafts are the same in all the 5 speed cars but was hoping to have someone with more knowledge than I chime in.
Thanks guys.
Thanks guys.
*might* fit, but I think some of the early model year B5's (96-97) came with carbon fiber drive shafts. My old 97 had one. I don't know why but I want to say the dimensions were different. Are you buying online or from a junk yard or what? At the very least I would double check the dimensions of yours versus the one you're looking at buying.
BTW - CCA, didn't you sell your B5?!
Since you're switching out the driveshaft, check for play in the frontmost rear differential mount.
The rubber on mine was starting to fail, so I filled in the gaps with windshield sealant (a replacement diff mount is hard to find and expensive).
Thanks Redmond, when I first got the gunk when shifting I suspected the front diff mount so I filled the gaps with some thick rubber to stiffen it up. I can pry on the nose of the diff and it barely moves now
redmond1501
11-25-2012 08:47 PM
