99 a4 1.8t boost problems
Old 12-30-2012, 03:41 PM
smokinwiz's Avatar
Default 99 a4 1.8t boost problems
around 3k rpms when my boost starts to kick in the lights on the dash flash then the car basically shuts off then once it drops a few rpms it will kick back in and shift but everytime it makes boost it freaks out and flashes lights and kills the car. no check engine light on unless it flashes when it dies
Old 12-30-2012, 03:53 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
The flashing check engine light is showing that you are misfiring.
The next step is to scan for codes. Do you have a vag com cable or know someone who does? If you do not you can buy one for $5 shipped on ebay, VCDS Lite (the diagnostic program) is free and will allow you to scan for codes.
You should have at least a P0300 (random multiple misfire) and P030X (X being a cylinder #).
Most misfires are caused by a bad ICM or coil, but we can't know until we talk to the car.
Old 01-01-2013, 06:31 PM
DillonT's Avatar
i had this issue when i first installed my chipped ecu. i closed the gap on my plugs a little, and it all went away.
Old 01-01-2013, 06:37 PM
george1546's Avatar
Try and replace the vacuum line from the DV, I had just done mine. If your car was fluttering after an ecu upgrade like mine was, I first thought its a BO but when I installed a boost gauge, the needle wasn't moving so I tracked the source and found that that vacuum line was completely gone. Ripped/Shredded. Got new one in, holding 15 psi, peaks at 17 and now producing a proper BO without any flutter. Good luck.
Old 01-02-2013, 09:11 AM
smokinwiz's Avatar
Any pictures of such line
Old 01-02-2013, 04:38 PM
george1546's Avatar
No pictures needed, look at your Diverter Valve, its the thinnest hose connected to it, remove it and fit a new one.
funon4wheels
11-26-2014 03:12 PM
KG_Gabriel
07-14-2010 10:47 AM
thatA4guy
04-12-2010 03:29 PM
brimhall99
11-03-2008 10:41 PM
acollicott
04-05-2008 06:16 PM
Quick Reply: 99 a4 1.8t boost problems
