cylinder 2,3 spark plugs/coil area filled with oil
Do i need new rings? i was changing my valve cover gasket and notice that cylinder 2/3 where filled to the top with oil covering the spark plug,the coil pack was covered in oil. could this be why I have a small oil/coolant leak thats not showing on my driveway and white/blue smoke coming out the exhaust?
What did I break? the piston rings? maybe thecylinder walls are pooped?I have very limited income so all work would be done by myself.
thanks
thanks
RE: cylinder 2,3 spark plugs/coil area filled with oil
its most likely the gasket between the cylinders. CLean it and put it back together. IF it comes back, we shall look for a new source. You can always do a compression test after to see if the rings are fine or not.
the valve cover comes with 2 parts. One goes around the outside and there is one that goes on the inside. Im talking about the inside one that goes like -0-0-0-0-.
Compression is like 180 on a new motor with 140 the min.
I replaced the spark plugs, the old ones where dry underneath and black, the top of the pistons looked dry too. so hopefully it was that gasket.
ORIGINAL: TeeterTawter
thanks
thanks
for the white/blue smoke... its definitely a blown head gasket.
g/l figuring it out.
drft1
07-05-2010 12:19 PM
