driving 100 miles on a bad powersteering pump
ok thats good to know, I drove about 25 miles right after the install and the "whining" sound did seem to get a LITTLE better.... i guess ill just give it some time. Thanks.
It was used pump overhauled/rebuilt by a company called Atsco. I bought it from Autozone for $185, they charged me a core price of $65 as well. I have now driven over 250 miles on the pump, same "whining" sound and it is more intense as the wheel is turned. However, The steering remains responsive and works great.
Thanks,
Matt
Thanks,
Matt
wow you're lucky it didn't explode on you. are you leaking ps fluid right now? i don't think you could have messed up the install, it's pretty straight forward. try using some lucas. the thicker fluid might help it
#18
Remove the suction line from the rack to the pump. Put it in a bucket. Have a friend pour new ps fluid into the reservoir while the car runs. Please note: Power Steering fluid is EXTREMELY FLAMMABLE! Do not spill it! This is not a recommended method, but can be used if necessary.
Also, check your hose clamps. If they are loose, the pump will suck air.
