Is driving with a bad ABS sensor damaging to brake system? - AudiForums.com
Reply
Thread Tools Search this Thread
Old 01-10-2011, 12:33 AM
Default Is driving with a bad ABS sensor damaging to brake system?
I have a bad front ABS sensor. This creates a weird noise/vibration in the brakes when doing slowly and applying the brakes.
Can anyone tell me what is actually happening to make this noise/vibration and whether it is harmful to continue to drive with the bad sensor?
I would prefer to wait for spring to replace the sensor.
Old 01-10-2011, 01:11 AM
vgo vgo is offline
you can pull the fuse for the ABS. Someone will have to chime in to tell you what and where the fuse/relay is or pm 'hiwords'.
I dont think that will get rid of your noise/vibration problem. Could be something else.
Old 01-10-2011, 01:12 AM
i dont think the sensor is the problem. i think your rotator might be warped which is causing the vibration
Old 01-10-2011, 03:45 AM
Moderator
I drove around like that for a little while, and my brakes still work after getting everything fixed up. Though I wish I had just pulled the ABS fuse as vgo suggested, would have gotten rid of the weird feel/noise.
Old 01-10-2011, 03:59 PM
It isnt harmful to drive with a bad sensor, but you might notice the car steers when you step on the brakes and you will not stop as quickly.. so it is best to pull the abs fuse (you can look it up in your owners manual, im not sure what it is), it is located where all of the other fuses are on behind the driver door jam or whatever its called.
The sound you are hearing is the abs hydraulic pump turning on (the hum), and the pulsing feel and sound is caused by valves rapidly opening and closing in the abs pump. The pump creates the same force as you pumping on the brakes, and the valves are to control what wheels receive brake pressure (similar to someone pumping the brakes, except more precise and rapid). ( http://auto.howstuffworks.com/auto-p...lock-brake.htm ) Pulling the fuse is your best option until you fix it, but you should remember that when you press the brakes hard enough, they will act as they would in an older car. They will lock up and be disproportional and cause you to fish tail and prevent you from steering if the wheels lock up since there is no abs control any longer. Pulling the abs fuse will also cause a flashing brake light and solid abs light on your dash.
By the way when you say noise and vibration, if you mean the entire car and not just the brake pedal vibrates, you have a problem with the regular brake system. And if noise you mean a screech or loud rubbing sound of some kind it also is not the abs system but rather the regular brake system. This would be something to be concerned about and is not fault of the abs system.
Reply
Thread Thread Starter Forum Replies Last Post
Is it my brake sensor switch? Or speed sensor or abs modulator? bobbyenglish61 Audi A6 4 08-27-2013 08:55 AM
Issue with brake system - Spongy brake with no caliper movement abc27 B5 Models 11 08-25-2013 05:19 PM
Driving with the brake on? kreiter B6 Models 0 01-18-2012 11:36 PM
EDL system+snow driving? Audi B5 Audi A4 0 12-08-2007 12:45 PM
Can driving "wrong" cause brake lights to come on? lkruvant Audi A4 6 09-18-2007 12:10 AM
Tags
abs, audi, bad, brakes, braking, causing, control, damage, driving, loud, noise, sensor, short, sound, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
