eccentric washer/bolt rear control arm stuck
For the life of me I cannot get the bolt out for the lower rear control arm that goes through the wheel bearing housing. All the washers spin with the bolt when I turn it so the bolt is free. Will the washers keep the bolt from coming out somehow? Is there a trick to getting the washers free of the bolt besides beating the crap out of the bolt?
Thanks
98 quattro 1.8
Thanks
98 quattro 1.8
I just did that one about 2 months ago. A sawsall works great. As bshusted said, the bolt is stuck inside that bushing. Make a cut on each end with the sawsall and it's out.
EDIT: When you put the new arm on, put plenty of anti-seize on there. Now you'll have to get an alignment, so might as well take the other side out and anti-seize that one too.
soundquest
01-13-2013 05:35 PM
Cubanator
11-13-2012 04:26 PM
