Ecu chipped
Ecu chipped
99 b5 with chipped ecu not sure how it works, there's a button causes check engine to flash need help how to properly use this read forum some say can switch different programs really don't explain much but if anybody have a similar set up or know about this set up would appreciate the help so i coulf be able to use it properly.
Well say if I push button once it will flash once push twice it will flash twice don't know this indicates 1 would be stock mode 2 chipped mode I started to to play with it say I follow sequence until the 4 flash then stops if hold button down about say 3 sec it will flash 4 times. So yup hope u could help me on this called apr really no help.
I know at first before finding button to ecu my boost was around 7 to 8 psi don't know what setting I switched into i believe it was 2 n went for a test drive and my boost was over 15 psi so I'll go back play with it figure out setting, now ? Is what type of ecu would it be what stage?
How can I find out of its an Apr? or some other type of chip n what stage it would be?
I have no idea. I had my ECU custom tuned to my specs. My tuner writes the firmware to reflect what I want, then it's just plug -n- play.
I'm not a big fan of the "everyone has one of these, so you should too" (IE. I'm one of the only guys on here that rides 20"s), so that leaves me pretty ignorant to things like this.
You might be able to look at the top of the ECU and see if it has some kind of sticker on it.
