Full Vacuum Hose Replacement DIY w/Pics?
Old 10-13-2013, 09:03 AM
A4TurboGuy's Avatar
Default Full Vacuum Hose Replacement DIY w/Pics?
Does anyone know where I can find a Full Vacuum Hose Replacement DIY w/Pics?
Yes: I've searched.
Thanks
Old 10-13-2013, 02:38 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Replacing vacuum lines is as simple as pulling the old line off, cutting the new silicone hose to the same length, and reattaching it. Do it hose by hose and you won't have a problem.
Here is a vacuum diagram for the AWM. Also, there may be a diagram on the underside of the hood.
Old 10-14-2013, 08:16 AM
A4TurboGuy's Avatar
Following lines is no problem. I just didn't know how many there actually were on the AWM.
This is perfect! Thanks!!
Old 10-14-2013, 02:17 PM
I just realized that the diagram I posted is for an AMB motor, it should be very similar (if not the same) as the AWM though.
Here is a little DIY I found: http://www.passatworld.com/forums/61...uum-hoses.html
Edit: This should be the AWM diagram.
Old 10-15-2013, 10:07 AM
A4TurboGuy's Avatar
I realized that as well.
Thanks for the update!
redmond1501
05-12-2014 02:55 PM
a2thy
01-06-2010 01:49 AM
danmcc86
11-03-2009 07:00 PM
Badman
09-15-2009 10:31 AM
Quick Reply: Full Vacuum Hose Replacement DIY w/Pics?
