Fuse Box Diagram
Fuse Box Diagram
Hey there
does anyone have or knows where i can find a diagram of all the fuses that are located on the side of the dash???
please help out because my power locks dont work anymore but the air pump works well because i am able to lock it using my trunk.
thanks
thanks
On mine, there is a numbered diagram on the inside of the fuse box cover, and then the owners manual has a list explaining the numbering system. Try that, but if you don't have the owners manual or somethin post again and i'll get a list of mine after work. holla!
yeah i bought the car without the manual and trying to invest some money into one or maybe borrow one from someone i don't know but if you could like take a picture of the page or retype it in i would appreciate that a lot.
Thanks bro
Thanks bro
Ok here ya go. I know I said I was gonna have this for you last night but some sh*t came up, sorry man. I'm gonna list them the way they are in the owner's manual:
1-Headlight washer jets
2-Turn signal flasher
3-Headlight washer, glove box light, engine bay light, instrument cluster
4-License plate lights
5-Instrument cluster, heated seats, auto trans display, outside air temp
6-Central locking system
7-ABS
8-empty
9-heated mirrors
10-empty
11-cruise control(auto trans)
12-on board diagnostic system
13-brake lights
14-interior lights
15-power windows, climate control
16-ABS, anti-slip(?)
17-heated door locks
18-right high beam
19-left high beam
20-right low beam
21-left low beam
22-tail and side marker (right)
23-tail and side marker (left)
24-wipers and washer jets
25-blower for heating/climate control
26-rear window defogger
27-empty
28-fuel pump
29-engine timing
30-sunroof
31-tail lights, cruise control, auto trans
32-engine timing
33-cig lighter
34-engine timing
35-trailer receptacle(?)
36-fog lights
37-radio
38-trunk light, central locking system
39-flashers
40-horn
41-empty
42-empty
43-heated seats
Ok theres the numbers. To figure out what the hell that means you have to look at the inside of the cover to the fuse box. Like Andrew said its very very faint. Good luck!
7-ABS
8-empty
9-heated mirrors
10-empty
13-brake lights
14-interior lights
18-right high beam
19-left high beam
20-right low beam
21-left low beam
27-empty
28-fuel pump
29-engine timing
30-sunroof
32-engine timing
33-cig lighter
34-engine timing
36-fog lights
37-radio
39-flashers
40-horn
41-empty
42-empty
43-heated seats
Boot opening problem
hi, i was wondering if you would be able to help me out here. Basically my boot wont open if you try and use your hand on the release part on the boot but if you use the key it will release the boot. so im guessing all the mechanisms are working but hopefully its just a fuse? and if it were just a fuse do you know which one it would be from the list above?
