Heated Seat Retrofit - AudiForums.com
Reply
Thread Tools Search this Thread
Old 12-14-2009, 02:29 AM
CycloSteve's Avatar
Member
Default Heated Seat Retrofit
Quick question...If I do not have the Winter Package in my 98.5 A4 2.8 which has the power leather seats, would those seats have the heating elements? No, the dash does not have the switches either.
I ask, as other manufacturers often install the elements in all seats, and all you need to do is add the switches in some cases, or switches plus a partial harness from a donor vehicle.
Definitely want the heated seats, and hoping that it might be easier than tearing into them and adding an aftermarket set of heaters.
Old 12-14-2009, 09:34 AM
Not sure, but look for the wires coming from the seats.
Old 12-14-2009, 10:51 AM
ImTheDevil's Avatar
I am pretty sure the seats with heaters were not fit without the controls. You'd most likely have to buy heated seats and put them in - I don't think you'll have the heating elements.
Old 01-28-2010, 12:14 AM
CycloSteve's Avatar
Member
Currently retrofitting a hybrid of OEM switches with aftermarket elements. Will post details once finished.
Old 01-28-2010, 12:30 AM
vgo vgo is offline
Old 01-29-2010, 12:24 AM
CycloSteve's Avatar
Member
Quote:
Originally Posted by vgo View Post
Definitely one of the threads that I have followed.
The only issue that I have found with that thread is that their wiring diagram/key of the connectors does not correspond with the actual pin numbers on the connectors, and only notes one of the two seat-end plugs. I am working up the actual pin-outs based on the EWD, and will post that with my write-up. This will help for those retrofitting with both the OEM elements, or the heatedseatkits.com ones.
Cheers,
Steve
Old 01-29-2010, 03:55 PM
ImTheDevil's Avatar
That is one hell of a comprehensive DIY procedure!
Reply
Thread Thread Starter Forum Replies Last Post
Retrofit Heated Seats team illuminata Audi A3 0 11-10-2011 01:10 PM
retrofit heated seats? rollyfoster Audi A3 9 07-26-2007 02:50 PM
Trade black heated power leather S4 seat(s) + cash for aftermarket seat(s) John Drivesabox Mid West 0 03-24-2007 07:10 PM
Heated Mirrors retrofit AndyA4C Electronics 0 10-15-2006 06:55 AM
B6 S4 Heated Seat Retrofit jza80 S Car Model Line 0 12-09-2005 02:35 PM
Tags
a3, a4, a6, audi, b7, cost, element, elements, heat, heated, heating, install, retrofit, seat, seats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
