Help with Diagnosis please!!
HI I have been looking at audis b5s for a while trying to get a low owner audi that has all records.. and found one yesterday that popped up, car runs and drives excellent with maint. records back to 2002... The only problem is I got in the car and as he said the dash looked like a xmas tree... abs, engine, airbag lights all on.... I have a printout of the diagnosis if anyone can help me read it and tell me approx. how much cash is needed to get this thing to pass inspection and clear the codes... thanks in advance
Friday,18,February,2011,22:30:32:57560
VCDS Version: Release 10.6.3 (x64)
Data version: 20101206
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 06B-906-018-AWM.lbl
Part No: 4B0 906 018 CH
Component: 1.8L R4/5VT G 0002
Coding: 16251
Shop #: WSC 63351
VCID: 69D4B49B39FF
1 Fault Found:
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 DF
Component: AG5 01V 1.8l5VT USA 1010
Coding: 00002
Shop #: WSC 63351
VCID: 74EAD5EF6E3D
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C3ADD4FA62D
2 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
30-00 - Open or Short to Plus
00285 - ABS Wheel Speed Sensor; Front Right (G45)
35-00 - -
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00140
Shop #: WSC 63351
VCID: 2D5C008BCD97
1 Fault Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-10 - Open or Short to Plus - Intermittent
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 2002
Coding: 00304
Shop #: WSC 63351
VCID: 3A763BD70CD9
1 Fault Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 Q
Component: B5-KOMBIINSTR. VDO D12
Coding: 02244
Shop #: WSC 13254
VCID: 397424DB09DF
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16140
Shop #: WSC 63351
VCID: 4082493F6A05
6 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63351
VCID: E0C229BF4AC5
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00200
Shop #: WSC 63351
VCID: 244AE5AF9E5D
1 Fault Found:
00-00 - -
End ---------------------------------------------------------------------
Coding: 16251
Shop #: WSC 63351
VCID: 69D4B49B39FF
1 Fault Found:
P1128 - 35-00 - -
Coding: 00002
Shop #: WSC 63351
VCID: 74EAD5EF6E3D
Shop #: BB 24334
VCID: 1C3ADD4FA62D
2 Faults Found:
35-00 - -
Coding: 00140
Shop #: WSC 63351
VCID: 2D5C008BCD97
1 Fault Found:
Coding: 00304
Shop #: WSC 63351
VCID: 3A763BD70CD9
1 Fault Found:
Coding: 02244
Shop #: WSC 13254
VCID: 397424DB09DF
Coding: 16140
Shop #: WSC 63351
VCID: 4082493F6A05
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00101
Shop #: WSC 63351
VCID: E0C229BF4AC5
Coding: 00200
Shop #: WSC 63351
VCID: 244AE5AF9E5D
1 Fault Found:
00-00 - -
Hello Kevin,
As i ran into you diag. log i see that you have some sporadic faults (intermittent) these can be easily cleared, just erase the fault using a VAS tester at a dealer ship or just remove the battery earth point for about 10min. then put it back on.
for the ABS you need to visual check on the FR speed sensor , if it's broken or check on the connector for loose contacts or cut in the wire.
If you have a check engine light on , please check fuel quality , and you may need to check on spark plugs and lambda probs.
hope these tips are good for you.
BR
BR
Tips are excellent... I was overwhelmed at first but after looking at it.. nothing to serious be sides the check engine which seems common with these cars after doing my research.. the car runs like a top without the lights on you wouldnt know anything was wrong with it... and now I fell in love with how the audis drive and handle...
If you don't have a crappy idle then your maf should be ok. The front ABS sensors report errors, you might have to change them or only clean them and push them deeper, and I don't like the "System too lean" error because it can have multiple causes and you might spend a lot of money to fix it.
Looking at audizine... they say that system running lean and that code is usually a maf or vacuum leak... I am going to take the maf out and clean it then try to figure out how to look for vacuum leaks, I am not sure what the crankshaft vent elbow is that is why I am asking, I have this idea from reading over his old reciepts and work orders. In October it had the same engine codes and the work order said if they come back on to replace the crankshaft vent elbow... anyone know where this is located? thanks
the lean mixture as you know is when you have excess amount of air supplied to the system. leaks in the vacuum system or intake ports won't give a lean mixture. what is the mileage of the car? have you checked on lambda probes signals?
