AudiForums.com
Go Back   AudiForums.com > Audi Models > Audi A4 > B5 Models
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Parts Search Today's Posts Mark Forums Read ExperienceGarageUsed CarsVendors TSBs
Search
Welcome to AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 08-03-2008, 09:22 PM
Default help with vacuum leak?
So I'm 95% positive that I have a vac. leak. My car can barely idle, and it often sputters and wants to die when it is idling correct. My vac guage is now reading 12 in/hg at idle, and then goes to the normal 22 in/hg when I get up to speed. CEL just came on today, and the car is in limp, only boosting 1psi with a GIAC chip. MAF is fine, just cleaned it last week, car ran great. New plugs and coils put in two weeks ago. I pulled the N75, and there's oil dripping out of it when I removed it. I'm going to pull out all the injectors and take a peek as soon as it stops raining out, but my money is on vac leak....
where should I look for the most problematic vacuum hoses? Any diagrams to help me?
thanks
__________________
1998.5 laser red A4 1.8TM Special Edition
Giac chip, Forge DVSplitter, Forge BC, Newsouth Boost Gauge, Greedspeed Snub, XM, Full Tint, 19" HR EVO's, two 12" Fosgate's, Ebay Halo's, RS4 Grille, JHM Short Shifter, Southbend Stage 3 Clutch
Old 08-03-2008, 09:36 PM
onepoint8tee's Avatar
Points: 19,149, Level: 87
Points: 19,149, Level: 87 Points: 19,149, Level: 87 Points: 19,149, Level: 87
Level up: 60%, 201 Points needed
Level up: 60% Level up: 60% Level up: 60%
Daily Activity: 2.8%
Daily Activity: 2.8% Daily Activity: 2.8% Daily Activity: 2.8%
Send a message via AIM to onepoint8tee
You have a CEL. It's probably smarter to get the fault code(s) from the ECU before getting your hands dirty.
__________________
Old 08-03-2008, 10:51 PM
Bogie's Avatar
Points: 4,949, Level: 44
Points: 4,949, Level: 44 Points: 4,949, Level: 44 Points: 4,949, Level: 44
Level up: 99%, 1 Points needed
Level up: 99% Level up: 99% Level up: 99%
Daily Activity: 1.4%
Daily Activity: 1.4% Daily Activity: 1.4% Daily Activity: 1.4%
Rubber vac line cost less than $0.50/ft, so buy 10ft and replace it ALL. The stock (Audi) braided vac lines dry rot too quickly and always start to leak.
__________________
2000 A4 1.8T Quattro, 034 High Flow Cat, Borla Cat-Back, STaSIS Coilovers, K&N Air Filter, Autometer Boost Gauge Forge 007P, SpeedTuning ECU, VVME 6000K HID bulbs, 034 snub mount.
Old 08-03-2008, 11:15 PM
Quote:
I already did.
bank 1/1 bank 1/2 running lean
__________________
Old 08-04-2008, 12:04 AM
steezybme's Avatar
fuzzduster-where should I look for the most problematic vacuum hoses?
Id start with the lines running off the n75, the main one that gave me trouble was the line running to the wastegate...
__________________
Audi is where its at, Quattro is what its about...
2000 B5 A4 1.8T
Old 08-04-2008, 12:27 AM
Tweaked's Avatar
Points: 4,518, Level: 42
Points: 4,518, Level: 42 Points: 4,518, Level: 42 Points: 4,518, Level: 42
Level up: 84%, 32 Points needed
Level up: 84% Level up: 84% Level up: 84%
Daily Activity: 4.4%
Daily Activity: 4.4% Daily Activity: 4.4% Daily Activity: 4.4%
Quote:
thanks
All of them!
I, too, recommend reading the DTCs to see what exactly the MIL is on for before chasing your tail, but here goes:
Most common is the breather hose setup. There is a "T" at the back of the valve cover that gets oiled up and collapses or splits. Follow it down and there is a plastic pipe (or metal if you have a late AWM) hose that attaches to a formed rubber hose that also collects oil and collapses or splits. I believe there is a check valve in one of those hoses that can also cause an interior vacuum leak. Follow the "T" the other way and you'll find a series of rubber elbows and connectors heading towards the airbox that can also cause issues.
Check the oil dipstick tube for cracks. Pull up on the dipstick. If the tube comes with it, replace the tube.
Additionally, there are about 16,000 feet of 1/4" vacuum lines that become dry and are only held together by the exterior webbing. Check all of them. Most common is the line to the FPR. It's short and towards the rear of the head. Additionally, there is a long line that runs from the DV to the intake manifold across the front of the engine. It tethers to the timing belt cover and often can collapse or chafe through.
Hope this helps.
__________________
01 A4 1.8TQM
Old 08-04-2008, 11:38 PM
Points: 3,649, Level: 37
Points: 3,649, Level: 37 Points: 3,649, Level: 37 Points: 3,649, Level: 37
Daily Activity: 1.5%
Daily Activity: 1.5% Daily Activity: 1.5% Daily Activity: 1.5%
Quote:
i also suggest checking this one out as it would easily explain your lean condition
__________________
2000 A4 1.8TQM - APR Stage 1
2001 S4 6 Speed - AWE Stage 3
Old 08-05-2008, 12:10 AM
ghost6303's Avatar
when at idle there isnt as much vac suction from the engine so a small leak would make a difference here. when you get up to speed theres more suction power, enough to mask a small leak. my vac is around -25 idle -27 @3200 rpm. you probably have a (few) decent size leak(s)
__________________
98.5A4TQM
Old 08-05-2008, 12:23 AM
Bogie's Avatar
All of them!
Hope this helps.
Good advice there. There's also the small lines at the front and back of the intake manifold, which are very easy to replace. And it's not 1/4", I know it's a much smaller I.D. than that. Just get about 8-10 feet and you'll have plenty.
__________________
Old 08-05-2008, 12:46 AM
update-
so today I took the codes off the car after double checking all the common problems and took it out for a spin. Its running strong, and sounds like its boosting 16 or 17 psi (like it should be) but its only boosting 5, and drops to 3 around the 4.5 - 6k rpms range. Vacuum was still being weird. So I decided to get underneath the car to be able to get a better look at some of the hoses that drop under the engine.
I found that the thick hose running from the turbo, down, underneath the engine block (also connected to the DV valve), and to the SMIC on the other side, had the clamps off! The hose ends slip onto a metal tube that connects them under the engine, and the tube was dripping oil, and the hoses were almost all the way off. So I slid them back on and clamped them tight. So I'll see if the car will balance out the running rich problem tomorrow, and HOPEFULLY run like its supposed to.
Oh and I took off the fuel rail to look at the injectors, and the last injector towards the drivers seat, has a broken head. It has two long cracks running though it, and it can swivel around. When I pulled it out of its seat in the manifold, all this oil/gas bubbled out and started hissing. So I need to replace that too.
__________________
Reply
Tags
18t, 1997, a4, audi, b5, car, diagram, diy, gauge, idle, leak, leaks, read, testing, vac, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
New Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
© Internet Brands, Inc.
Emails Backup
