help with vacuum leak?
So I'm 95% positive that I have a vac. leak. My car can barely idle, and it often sputters and wants to die when it is idling correct. My vac guage is now reading 12 in/hg at idle, and then goes to the normal 22 in/hg when I get up to speed. CEL just came on today, and the car is in limp, only boosting 1psi with a GIAC chip. MAF is fine, just cleaned it last week, car ran great. New plugs and coils put in two weeks ago. I pulled the N75, and there's oil dripping out of it when I removed it. I'm going to pull out all the injectors and take a peek as soon as it stops raining out, but my money is on vac leak....
where should I look for the most problematic vacuum hoses? Any diagrams to help me?
thanks
thanks
I, too, recommend reading the DTCs to see what exactly the MIL is on for before chasing your tail, but here goes:
Most common is the breather hose setup. There is a "T" at the back of the valve cover that gets oiled up and collapses or splits. Follow it down and there is a plastic pipe (or metal if you have a late AWM) hose that attaches to a formed rubber hose that also collects oil and collapses or splits. I believe there is a check valve in one of those hoses that can also cause an interior vacuum leak. Follow the "T" the other way and you'll find a series of rubber elbows and connectors heading towards the airbox that can also cause issues.
Check the oil dipstick tube for cracks. Pull up on the dipstick. If the tube comes with it, replace the tube.
Additionally, there are about 16,000 feet of 1/4" vacuum lines that become dry and are only held together by the exterior webbing. Check all of them. Most common is the line to the FPR. It's short and towards the rear of the head. Additionally, there is a long line that runs from the DV to the intake manifold across the front of the engine. It tethers to the timing belt cover and often can collapse or chafe through.
Hope this helps.
All of them!
Hope this helps.
Hope this helps.
update-
so today I took the codes off the car after double checking all the common problems and took it out for a spin. Its running strong, and sounds like its boosting 16 or 17 psi (like it should be) but its only boosting 5, and drops to 3 around the 4.5 - 6k rpms range. Vacuum was still being weird. So I decided to get underneath the car to be able to get a better look at some of the hoses that drop under the engine.
I found that the thick hose running from the turbo, down, underneath the engine block (also connected to the DV valve), and to the SMIC on the other side, had the clamps off! The hose ends slip onto a metal tube that connects them under the engine, and the tube was dripping oil, and the hoses were almost all the way off. So I slid them back on and clamped them tight. So I'll see if the car will balance out the running rich problem tomorrow, and HOPEFULLY run like its supposed to.
Oh and I took off the fuel rail to look at the injectors, and the last injector towards the drivers seat, has a broken head. It has two long cracks running though it, and it can swivel around. When I pulled it out of its seat in the manifold, all this oil/gas bubbled out and started hissing. So I need to replace that too.
