How much refrigerant does it take to fill up the A/C?
I've noticed my A/C has been blowing warm air. Checked the pressure on the low-side port and it was low (about 17psi) so I bought an 18 ounce of R-134A refrigerant to recharge/refill AC.
The can is almost empty but the gauge went up only about 9psi at first and then stopped at 28psi which is low for temperatures around here it needs to be at 45psi. Does it really take more than 1 large can to refill?
first of all dont ever put that **** in ur ac frigerant u will get air in your compressor and run it dry so dont do it you must have a vacumm suck your lines all dry than you put the refrigerant in do it right or pay 2grand to fix it
The fill spot is in the right corner of engine compartment near the firewall... the high port and low port are both there u need the thicker tube.
Image.
http://www.id-usa.com/images/illustr.../LowSide-7.jpg
Image.
