how to remove quattro, rear driveshaft at rear diff. - AudiForums.com
Reply
LinkBack Thread Tools Search this Thread
Old 09-01-2012, 12:44 AM
Default how to remove quattro, rear driveshaft at rear diff.
not sure why, removed the bolts did a little hammering still not movement, letting the penetrate to eat the rust overnight, any ideas? front at tranny came out nice and easy.
Old 09-01-2012, 08:55 AM
Moderator
You pop the center carrier off also? Should just be able to persuade it with a metal hammer.
Old 09-01-2012, 12:05 PM
Quote:
yeah driveshaft support is removed also, thats the reason why im doing this. replace that worn out original one.
Old 09-01-2012, 09:31 PM
Tweaked's Avatar
Don't whack it with a metal hammer, you can damage the joint. It just takes some time to walk it off using a deadblow. It's a large joint, and often gets stuck.
Old 09-02-2012, 08:02 AM
b5blazing's Avatar
Laying under car put one hand on drive shaft and one hand on diff snout. Shake vigorously should separate. Metal hammer no dead blow or rubber malet yes.
I know mine hit me in the face when I popped it out last time.
Old 09-03-2012, 05:53 PM
successfully removed it, just let the wd 40 rust penatrint to work, was just stuck and sezsed replaced the driveshaft support fixed that vibration when under a load, just wondering if theres a proper way to align the driveshaft i still have a little vibration in first, when doing 4g launchs
Reply
Thread Thread Starter Forum Replies Last Post
1999 Audi A4 2.8 Quattro rear diff Luiggi B5 Models 5 10-04-2014 01:19 PM
Quick Differential Question!! Rear diff Ratio of B6 3.0. Diff stamped ELE MKIV_TDI B6 Models 2 01-09-2014 10:33 AM
2001 Allroad 2.7T rear diff leak driveshaft Kevin Artz Allroad Model Line 7 09-18-2013 06:10 PM
Can't remove the rear driveshaft help! justinm001 Audi A6 5 02-22-2010 11:45 PM
quattro rear diff question iano Audi A4 3 05-01-2006 09:31 PM
Tags
a4, audi, b5, diff, disconnect, drive, driveshaft, loosen, quattro, rear, remove, removing, shaft, stuck, tt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
