how to remove quattro, rear driveshaft at rear diff.
Old 08-31-2012, 11:44 PM
moneyfresh's Avatar
Default how to remove quattro, rear driveshaft at rear diff.
not sure why, removed the bolts did a little hammering still not movement, letting the penetrate to eat the rust overnight, any ideas? front at tranny came out nice and easy.
Old 09-01-2012, 07:55 AM
jonbonesjones's Avatar
Moderator
You pop the center carrier off also? Should just be able to persuade it with a metal hammer.
Old 09-01-2012, 11:05 AM
moneyfresh's Avatar
yeah driveshaft support is removed also, thats the reason why im doing this. replace that worn out original one.
Old 09-01-2012, 08:31 PM
Tweaked's Avatar
Don't whack it with a metal hammer, you can damage the joint. It just takes some time to walk it off using a deadblow. It's a large joint, and often gets stuck.
Old 09-02-2012, 07:02 AM
b5blazing's Avatar
Laying under car put one hand on drive shaft and one hand on diff snout. Shake vigorously should separate. Metal hammer no dead blow or rubber malet yes.
I know mine hit me in the face when I popped it out last time.
Old 09-03-2012, 04:53 PM
moneyfresh's Avatar
successfully removed it, just let the wd 40 rust penatrint to work, was just stuck and sezsed replaced the driveshaft support fixed that vibration when under a load, just wondering if theres a proper way to align the driveshaft i still have a little vibration in first, when doing 4g launchs
Luiggi
10-04-2014 12:19 PM
Kevin Artz
09-18-2013 05:10 PM
justinm001
02-22-2010 10:45 PM
iano
05-01-2006 08:31 PM
Quick Reply: how to remove quattro, rear driveshaft at rear diff.
