Plug gapping
Old 06-19-2012, 01:00 PM
makaveli7's Avatar
Default Plug gapping
Ok so I just got my ecu done with stage two programming, the car run fines and I have not re gapped the plugs from the regular .032. Oliver at speedtuning told me it was not necessary but a lot of people here tell me to goto .028, anyone have input?
Old 06-19-2012, 01:06 PM
MetalMan's Avatar
Moderator
Generally this is a requirement if you have an AEB engine because the AEB uses the weaker/crappy ICM and coil pack setup. I can imagine getting away with a larger gap on 2000+ 1.8T cars though. But it's a good idea anyways because you'll be pushing a lot more through the plugs.
Old 06-19-2012, 01:12 PM
makaveli7's Avatar
So Aeb is ? My car is 2000 automatic Quattro 1.8 t, just regap them to .028 even if it's running fine?
Old 06-19-2012, 01:55 PM
CCA4's Avatar
AEB is 97-99.5. Your engine code is ATW, 2001+ is AWM.
EDIT: Thought I would clarify that ^this^ only applies to NA 1.8T motors. Your results may vary.
If it runs fine, then why mess with it? If it starts running badly down the road, move re-gapping the plugs to the top of your list.
DanaB6
07-07-2012 01:39 PM
audiquattroa4
05-04-2010 10:43 PM
alan93
01-29-2010 10:13 PM
Sublime865
09-10-2008 02:44 AM
ChadS89
07-19-2008 10:33 AM
Quick Reply: Plug gapping
