Tb adaption
Tb adaption
How do i do it? I got
a new ecu thats same code and also from a quattro manual but when i installed it and started the car it surged between 600 and 200 rpms almost stalling constantly. I heard this will solve that. Thoughts? How to?
turn the key to turn the electric on and let it sit you should hear some electric actuators and **** moving under the hood let it sit for 3-5 min that should do it. I'm not sure if its the same level of adaption as vag com but i know that a tb adaption and it works
It's not as precise as forcing it with Vagcom but do it 3x with a few minutes between each and it'll get you pretty close. From that point, the ECU will learn the rest on its own with some driving.
crazyquik22023
09-09-2011 08:06 PM
