License Plate Lights Not Working - AudiForums.com
Reply
Thread Tools Search this Thread
Old 05-04-2012, 02:11 AM
Unhappy License Plate Lights Not Working
I replaced my blubs, checked the wires, fuses, and everything else involved! My lights will not work! And I KEEP getting pulled over for no lit up license plates! has anyone dealt with this problem before? or know how to fix it!?
I WOULD LOVE SOME HELP!!!
Old 05-04-2012, 02:12 AM
Rear liecense plates** both lights**
Old 05-04-2012, 03:38 AM
clean the sockets? mine were so corroded that they weren't making a good connection... i used some sandpaper and scratched them up and they've been working again for 6 months. if you know the socket is getting power (use a meter), you could just wire them to the tail lights independently.
Old 05-04-2012, 07:32 AM
vgo vgo is offline
I repaired mine not too long ago. I pulled out the trunk lid liner and found the sockets corroded and fused together. I soldered in a new wire and has been working since.
Old 05-04-2012, 07:37 AM
CCA4's Avatar
The trunk lights in my old B5 did the same thing as vgo's. They were so corroded they stopped working. I ended up replacing the housings cause I didn't feel like dealing with it lol.
Old 05-04-2012, 07:52 AM
vgo vgo is offline
As CCA4 suggested, you replace the housing/set because it is a lot less of a hassle. You can get them from ECStuning.com BUT they are always on back order =(
Everytime I order something from ECS, the price doubles when it crosses customs so I try to refrain from ordering there now.
Old 05-04-2012, 10:36 PM
GusTaVz_a4's Avatar
mine werent working for about two months and all it was that i had them flipped the wrong way....
Old 05-05-2012, 07:08 AM
M5S5's Avatar
Tech Certified
A simple voltmeter test would help answer your question. You should have at least 12 volts & a good ground at the light sockets. If it is found that there is no power at the sockets i would check the wiring where they go from the trunk to the body of the vehicle. They have a tendency to break from years of bending from the trunk opening & closing.
Old 05-06-2012, 12:00 AM
vgo vgo is offline
I don't think polarity matters if its your regular filament bulb. It will matter if its LED.
Old 05-06-2012, 12:22 AM
ImTheDevil's Avatar
The issue with mine was the wire connections on the back of the housing. They were rotted badly and one wire had broken away. The metal was so bad that I couldn't even solder to it. I found the whole setup on a parts car - housings, lenses, body-color shell that contains everything - for $3. Took it home and swapped the whole thing out. Works great.
I agree with the guys above - replace the housings. It doesn't take long and is a lot less crap to deal with.
Reply
Thread Thread Starter Forum Replies Last Post
One License plate light not working Pbcrazy B5 Models 7 09-06-2012 05:06 PM
Trunk Light and License Plate Lights Not Working LoriV Audi A4 5 05-04-2012 02:02 AM
Trunk lights and license plate lights exequiel3k B5 Models 8 09-13-2009 05:47 PM
License plate lights Stevenw83 B5 Models 2 10-09-2008 07:37 PM
license plate lights berz153 General Tech 1 10-26-2007 10:31 AM
Tags
04, a4, a8, audi, dont, illumination, licence, license, lights, plate, platr, problem, pulled, work, working, wtf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
