Loosing Lots of Power Steering Fluid??
So when i bought my 97 a4 2.8 12v... the previous owner said he brought the car to the audi dealer to have the power steering pump replaced... proof is in the receipts and everything... but now its loosing power steering fluid and im not sure where its coming from... i still havent gotten a chance to jack the car up and inspect the bottom but just wanted to ask you guys to see if you guys have any ideas?? im not sure if this is a common problem but i thought i'd give it a shot...
any help would be appreciated... thanks
Rack??
I've been battling steering issues in my 96 since I bought it. Check the boots on the end of the rack. The steering rack seals are prone to leakage and cannot be replaced. If this is the case you are looking at replacing the rack. There are some very good DIY's out there on replacement but from what I've heard it can be a real pita. The problem I've had with my car is all the ps lines. The pressure line that comes off the pump is known to separate where it transitions from steel to rubber hose. Also the line from the reservoir to the pump goes from rubber to steel and back to rubber again and Audi decided to use these crappy one time use clamps on them that leak like a sieve, causing the ps pump to suck in air and make horrific Beluga whale type noises...
Hope this helps and good luck, and remember to use the correct Audi ps fluid to top it off.
thanks guys... but i checked the boot of the rack on both sides and doesnt seem to be any leaks... the area around the reservoir is really oily though but i can really trace where its coming from... the ps pump looks brand new so maybe its the reservoir.. and i use pentosin chf 11s
Here's the DIY. It's for an A6, but the procedure is nearly the same (you dont have to remove the headlight on an A4 B5): http://www.audizine.com/forum/showth...luid-flush-DIY
my rack is leaking pretty badly.. every few days filling it. also, the suction hose, from the reservoir to the pump where it goes from rubber to metal, was leaking too. so i replaced the line with some 5/8th hose from a parts store and that seemed to slow the leaking down. the rack is still shot, can't do anything about that besides replacing it. you may be leaking into the boot, but the boot is leaking behind so you can't see it. you have to really get up in there and inspect the boot. maybe poke a hole in it, see if fluid comes out.
Okay so i checked it out at a shop the car was on a lift and everything and its leaking fluid for sure... from where? its leaking like crazy from the passenger side rack -_____-
so now i know where its leaking from... how do i replace the rack? seems impossible ! :'(
