Loosing my mind over a vibration
Old 03-03-2011, 09:06 PM
sa9023's Avatar
Default Loosing my mind over a vibration
My car has had a vibration since I got it, coming from the back. Bad wheel bearings have been changed since. Now, the vibration got worse when I put my 19" HP Evo wheels on but that was before the wheel bearing change. After I replaced them it's still there. Had my wheels rebalanced today and nothing changed. From what I'm hearing I need hub centric rings. But my question is, would it only vibrate at 50+ mph? I mean a pretty bad vibration, one that makes me not take my car on the interstate at all right now. I'm lost, and frustrated...
Old 03-03-2011, 10:34 PM
theflash's Avatar
The only other thing I can think of is the rim is bent or the belts in the tires have snapped, but that only happens when the tires are really really worn. Besides, you just had them balanced, the shop would have spotted either problem easy.
So it should be hub centric rings. If you had stock wheels you could test if you get the same vibration or not.
Old 03-03-2011, 11:29 PM
flynnr's Avatar
rings!
Deeman
06-07-2012 02:28 PM
supersix4our
12-11-2011 05:45 AM
jt's A4
06-04-2009 12:39 PM
Indiepunk
06-01-2007 07:25 PM
y2karnival
02-24-2006 09:19 PM
Quick Reply: Loosing my mind over a vibration
