Loud Whistle Under Boost
Ever since I got the car I get a very loud whistle when I boost. It's only seems to be at full boost (10-12 PSI) I'm not sure if it just the turbo or a boost leak or something else completely. I seem to hold PSI fine so it doesn't seem like a boost leak but shoot me some ideas on what it could be.
A lot of people recommended them. It was $199 compared to other companies which run $400+. Same HP and torque gains just less boost.
Doesn't work like that. Two good quality stage 1 tunes for a k03, one running 18psi and one running 12psi the 18psi will win. I'm wondering if you have a vacuum leak or similar somewhere. I can't imagine a tune only going from the stock 7psi to 12psi
I contacted multiple companies and the HP and torque gains were almost exact. So I don't know what to tell you.
I know, that's why I'm saying you might have a vacuum leak. It could also be your turbo is getting bad and it isn't building full boost (16psi+)
Or maybe the turbo is bad and if that's the case well oh well 12 PSI works.
