Low pressure AC port
anyone figure out where the low pressure line is on a 96 B5? Some audi dealer mechinic said its possibly above the right front wheel well. I cant find it. Also do you know if your standard carquest freeon will work.
Max
Max
RE: Low pressure AC port
there isn't one, you have to get an adapter for the high port to make it a low and then charge it. check your local auto parts stores to see if they have the adapter. otherwise you'll have to take it to the dealship
no idea but pm auditech79, he should know
this is it http://cgi.ebay.com/ebaymotors/A-C-H...3286.m20.l1116
I had the same issue with my 96 I just purchaced, had to take it to Jiffy Lube it cost 110 bucks to get it recharged. No auto parts stores could give me any help. But my A/C is super nice and cold now, its great!
hiwords, You should give these guys a heads up that charging through the high pressure port is dangerous and they can get injured easily by using a can on it. I add some to mine sometimes through the high pressure port but I leave the engine not running and turn the can upside down to add it as liquid. If you start the engine with compresser running you will have enough pressure in the high side to burst a small can. I don't want to see anyone getting injured doing this...
Good Luck...
Good Luck...
i've actually never charged from the high side b4 so i wouldn't know any of those dangers lol. my car has a low side, phew lol. good luck man, make sure you report back so we know you didn't kill ya self
ORIGINAL: Redrum1
Good Luck...
Good Luck...
