VVT on AEB head? Can YOU tune it out for me?
Old 06-18-2019, 02:12 PM
A4TurboGuy's Avatar
Default VVT on AEB head? Can YOU tune it out for me?
Hi Guys,
I just built a BT setup (AWM block w/AEB head, using the AEB cams and tensioner). I've read every damn post on VVT in every damn forum and no one seems to know exactly what they're talking about. My last build was the same, but I used the AWM cams and VVT tensioner & solenoid.
Is it better to use the AEB cams w/ no VVT, or should I swap out my cams & tensioner for the AWM/VVT setup? Is there any real power difference between these two (since the AEB cams are bigger)?
Also: If it's better to use my current AEB top end w/ my AWM bottom end, is there anyone here that can tune the VVT out of my ECM? I have a stage 2 with two-step, etc. I just need someone to dial in and delete VVT for me.
Is there anyone who can give me legit answers (not guesses) on this?
Thanks
Old 06-19-2019, 03:53 PM
A4TurboGuy's Avatar
Bump.
A4TurboGuy
02-17-2019 06:01 PM
A4TurboGuy
10-13-2018 01:38 PM
Endless8
01-27-2017 09:41 PM
Endless8
01-27-2017 09:39 PM
teamwork123
02-11-2014 09:49 PM
Quick Reply: VVT on AEB head? Can YOU tune it out for me?
