My very own update thread
Old Oct 4, 2013 | 10:21 PM
  #371
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Alright I'll go grab some.
Old Oct 5, 2013 | 04:07 AM
  #372
******' lovely. Spent ~10 hours today pulling the axle flange and transmission side cover to replace the magnetic ring inside and I'm still getting VSS implausible signal. Speedometer works intermittently.
I don't know where else to start looking and I'm beyond frustrated. Way too much time and $ to try and get a working speedometer and no CEL...
Old Oct 5, 2013 | 09:58 AM
  #373
smittylube's Avatar
Does the ECM get it from the cluster? If so u may want to check your wires or cluster. Just thinking. I can look at the schematic at work on Monday
Old Oct 7, 2013 | 12:10 AM
  #374
smittylube's Avatar
Just got Elsawin going I can look there also.
Old Oct 7, 2013 | 03:16 AM
  #375
Thanks smitty.
Here is my trace of the circuit:
From the VSS the signal passes through a brown/red wire into the instrument cluster through pin 23 on the blue connector. After going through the cluster processor/speedometer it passes out through a white/blue wire on pin 6 of the yellow cluster plug into pin 20 of the ECU. Because my car was made before 8/97, the same signal from pin 6 on the yellow cluster plug goes to the cruise control module, pin 9.
Since my cluster doesn't seem to be receiving the signal I'm going to start with the wiring from the VSS to the cluster and see if there are any problems. Then I'll dig into the CC module.
Unfortunately I won't have access to the garage for a few more days.
Old Oct 7, 2013 | 09:44 AM
  #376
bshusted's Avatar
Do you have access to an oscilloscope? If so, you could probe the plug at the base of the sensor and then again at the cluster to see if the pulses are going through. From the pictures I've seen, it appears that the VSS is based on the speed of the driver's front wheel. If you just jack up the front and spin that wheel, you should get a signal if all is well.
Old Oct 7, 2013 | 12:51 PM
  #377
Nope, no oscilloscope. I'm going to start by running an extension off the brown/red wire back to the cluster to check for continuity and see if I have a broken wire. Then jack the car up, spin the wheel, and see if I get a voltage change.
Old Oct 7, 2013 | 01:02 PM
  #378
bshusted's Avatar
A standard DMM may not be able to read the potential change from the spinning wheel. You can check for continuity from the wheel sensor to the cluster.
Old Oct 8, 2013 | 12:09 PM
  #379
smittylube's Avatar
Your in the city right? I'm in Mt view. not far. I do have a lab scope. You should check for voltage and ground to the sensor if you have a fluke meter or similar.
If you want you can come by the shop and we can sort it out.
Old Oct 10, 2013 | 12:57 AM
  #380
Thanks for the offer Smitty, I'll let you know if I can't get it sorted. I'm over in Berkeley right now.
Here are the rest of the pictures from changing the VSS gear ring. I was in a rush so didn't take as many pictures as normal.
Two M8x1.25 bolts being used to drive out the output flange. Using a couple pieces of aluminum to protect the transmission cover.
Output flange removed.
New gear ring.
Old compared to the new. Notice the lack of a "locating tab" on the new ring. It ended up locking into place with the side clips anyways.
Transmission side cover removed, gear ring uninstalled.
