Need to drain the coolant to change thermostat?? - AudiForums.com
Reply
Thread Tools Search this Thread
Old 02-21-2008, 12:17 PM
CIA CIA is offline
Default Need to drain the coolant to change thermostat??
My thermostat is malfunctioning. I want to change it. My questions is do i need to drain the coolant in order to change the thermostat or its removal(old one) and installation of the new one?
Thank you
PS. Haynes repair manual says that they drain the coolant...
Engine ATW 1.8T 2000 manual
Old 02-21-2008, 01:05 PM
Trey25's Avatar
Default RE: Need to drain the coolant to change thermostat??
It wouldn't hurt would it...Actually it would if the coolant is hot/warm
Old 02-21-2008, 01:32 PM
Bogie's Avatar
Drain it. Red drain plug is on the driver's side of the radiator.
Old 02-21-2008, 02:13 PM
pyropenguin's Avatar
The only way you wouldn't have to drain it is if you could hold your car upside down while changing it so the coolant doesn't flow out of the hole.
Just flush it, it's good for your car anyways.
Old 02-21-2008, 02:16 PM
no need to drain just replace it and bleed the system when your done
Old 02-21-2008, 03:18 PM
CIA CIA is offline
how do i bleed the system?
Old 02-21-2008, 03:25 PM
let the car warm up with the radiator cap off.
Old 02-21-2008, 09:00 PM
Quote:
ORIGINAL: techbod
I remember having to take the lower radiator hose off of the waterpump to change the thermostat... Am I remembering wrong or will this not drain the fluid anyways?
Old 02-21-2008, 09:07 PM
CIA CIA is offline
sure, if i have to remove the lower radiator hose in order to change the thermostat, its clear that a drain is needed.
PS. i didnt get under the car yet. Today its -20 below...tomorrow with a 1-2C it will be perfect
hiwords's Avatar
nope, if you leave the reservoir cap on and have the thermostat facing upwards, only some fluid will leak out. when you go put the new one back in, have someone unscrew the reservoir cap while you're pushing down on the thermostat. i put mine in with the reservoir cap on and it was hard as a **** lol
Reply
Thread Thread Starter Forum Replies Last Post
Thermostat Change grease Audi A8 3 05-05-2011 10:12 AM
Coolant Temp Low After Thermostat Change katiebear00 Audi A6 12 02-28-2010 02:19 AM
need help how to drain coolant cmacelo121 B5 Models 5 09-19-2009 06:01 PM
Coolant drain plug?? Pic? Agnt008 Audi TT 3 02-29-2008 03:43 AM
I need to change my thermostat pearlcfcivic Audi A4 44 01-21-2008 04:26 AM
Tags
18, a4, audi, b5, bleed, change, coolant, diego, drail, drain, empty, flush, honda, rad, replace, san, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
