Oil on the spark plugs help?
Old 02-16-2010, 03:20 PM
y^0's Avatar
y^0
y^0 is offline
Default Oil on the spark plugs help?
Need some help, a while back, my cel came on, and of course i go and get one of those free diagnostics at autozone. i get code number P0432, and assume that it is something that can wait for a little while. Well, today, i just swapped out my spark plugs and changed the air filter, but when i changed the spark plugs, i had four that had oil on the threading of the plugs, and two that were completely normal. any ideas of what this could indicate?
Old 02-16-2010, 03:23 PM
Andrew149's Avatar
:Main catalyst efficiency below threshold (bank 2)
Old 02-16-2010, 03:25 PM
y^0's Avatar
y^0
y^0 is offline
yes, i know what the code means, but ime wondering if that has anything to do with why the spark plugs are oily.
Old 02-16-2010, 03:38 PM
Andrew149's Avatar
lol no spark bad spark plugs would make your engine stumble
Old 02-16-2010, 03:56 PM
y^0's Avatar
y^0
y^0 is offline
ahhh, ok. i was afraid that i had blown a head gasket somehow.
Old 02-16-2010, 04:37 PM
Andrew149's Avatar
if you blew a head gasket your car will smoke and be using alot of oil
Old 02-16-2010, 04:49 PM
bbboy's Avatar
Member
It's a valve cover gasket. Ours have 2 pieces, mine also leaked around the spark plugs. There is a DIY on passat forum
http://www.taligentx.com/passat/main...vecovergasket/
Old 02-16-2010, 04:56 PM
Andrew149's Avatar
depends if he has a 1.8t or a 2.8
Old 02-16-2010, 05:04 PM
y^0's Avatar
y^0
y^0 is offline
it's a 2.8, not using much oil at all, and no excessive or blue smoke coming out of the exhaust. it has been starting hard this winter though
Old 02-16-2010, 05:12 PM
Andrew149's Avatar
well just change the plugs use ngk's by what i understand people on the fourms say the ngk's work better than the bosche and im running the bosche with no issue's when you change the plugs just check back in a few 1000 miles and see what you get but i wouldnt worry about that at all
Quick Reply: Oil on the spark plugs help?
