05-17-2012, 11:21 AM
Level up: 96%, 2 Points needed |
Power Steering Mineral Oil problem
Hi all
Greetings from SA. I installed a new power steering pump last week and the guys that worked on my car put in normal hydraulic oil instead of the Pentosin Mineral oil specific for my Audi
Now I am experiencing issues when turning the car, then there is power steering then there is nothing (while turning). This is very dangerous and want to flush the oil and replace it with the proper Pentosin mineral oil.
The Audi mechanics told me to bring in the car and they will flush it which will costs thousands of Rands. According to them they will have to flush the steering rack as well etc
Here is my question - Can I just drain the oil where it goes into the pump and put in the normal mineral oil?
Hope you guys can help
Keep up the good work!!
05-17-2012, 11:59 AM
Level up: 71%, 44 Points needed |
Here's a DIY (it will flush the rack). It's for a B6, but it's the same procedure, with the exception that you don't have to remove the headlight. The use of a golf tee is ingenious:
power steering fluid flush DIY
Be sure to clean the filter located inside the reservoir with some carb or brake cleaner.
__________________
1998 2.8 30v Quattro AHA
05-17-2012, 05:18 PM
Level up: 54%, 46 Points needed |
Quote:
No. Get it all out. And the shop should do it...make them get it all out.
__________________
99.5 A4 Q 2.8 - 179,000 miles
Hibiscus Red Mica
05-17-2012, 07:11 PM
Level up: 57%, 43 Points needed |
tell the shop to drain it all out and you shouldnt pay anything because its their fault that they didnt use the right fluid.. if they dont flush ur powersteering for free you should report their asses
__________________
97' Audi A4 2.8 Quattro 5 spd. = Short Shifter = K&N Drop In Filter = Magnaflow = Eibach Springs = Projector Headlights w/ 5k HID's = B7 A4 Rims
05-23-2012, 09:32 AM
Power Steering Flush
Thanks guys for the advice...
I flushed the whole power steering pump etc and purchased the correct oil. All sorted!
Again...you guys are doing a magic job with your advice and help!!!
05-23-2012, 11:50 AM
glad to hear it worked out for u...
__________________
06-21-2012, 12:21 AM
Level up: 38%, 31 Points needed |
Feck! I just dumped brake fluid into my power steering reservoir. Have not run the car. What does anyone recommend?
06-21-2012, 07:08 AM
Points: 13,042, Level: 74 |
Level up: 48%, 208 Points needed |
Do the flush in the link above in this thread. Your situation is the same as the OP's - wrong fluid in the system - so the fix is the same too...
__________________
ImTheDevil / 1999 30vqm
06-21-2012, 09:49 AM
I wonder if I can't get away with just draining the reservoir, as none of the brake fluid was ever circulated through the system.
06-21-2012, 09:57 AM
You can try but it will have mixed through. Your car and decision but I'd flush it to avoid the risk.
__________________
Tags
28, 97, a4, audi, b5, diy, fluid, flush, golf, mineral, oil, power, powered, quattro, stearing, steering, tees, vbulletin  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
