03-13-2011, 02:56 PM
Level up: 20%, 120 Points needed |
Push clutch to start?
So yesterday I got in the car and went to start it but a message came up saying " push clutch pedal to start" obviously I already had the clutch in so I was alittle confused. Tried to start it and it wouldn't turn over. Turns out to just be the battery but even today when I replaced it , I still get the same message. After I start the car I get the "ok" but the cluth message before I start still puzzles me. Any ideas?
03-13-2011, 03:34 PM
Level up: 54%, 70 Points needed |
I'd just hook it up to a vag and clear any possible codes.
Idk how it reads when the clutch is pusghed in, I'd assume a sensor of some sort, wich could be the culprit, but I have NO idea.
03-13-2011, 03:36 PM
Level up: 96%, 4 Points needed |
Maybe the master cylinder is starting to wear out, so its not fully engaging the starter?
03-13-2011, 03:58 PM
Tech Slut
Level up: 83%, 34 Points needed |
Theres just a small switch under the clutch pedal that gets engaged when you step on the clutch and allows the ignition to kick on. Im not sure why you would suddenly be getting that message tho. I'm assuming this is a facelift A4 right?
__________________
The BatWagon
'99 2L BAT A4
03-13-2011, 08:38 PM
Trunk Moderator
Level up: 10%, 180 Points needed |
Quote:
I would think so, my 97 didn't need the clutch pedal pressed in to start it.
__________________
01.5 A4 Avant 1.8TQM: Tuned by K0mpresd|CM FX300 240mm|19lb LWFW|Stėrn|Neuspeed Race|3" RAI TP|Panzer Plate|Red Stuff,A8,TT|K&N|APR TIP|710n|034 Catch Can|Sport Cloth Seat Swap|SSAC cat back
03-13-2011, 09:17 PM
Tech Slut
LOL really? My 99 wont start without the clutch depressed. And I said he must have a facelift, cuz I dont think the pre-facelifts have the capabilities of saying that to you lol.
And CHRIS, why did you delete your FB again? I lost my late night fap material
__________________
The BatWagon
'99 2L BAT A4
03-14-2011, 08:13 AM
Trunk Moderator
rofl you weren't supposed to be able to do that?  good thing i sold that car!
I know I'm sorry! Some investigation stuff goin on with work, FB will return as soon as thats over lol. You sell that Milltek cat back yet? I may have to come take it off your hands
/threadjack
__________________
03-14-2011, 11:54 AM
Tech Slut
Quote:
/threadjack
I thought you got paid to be on facebook tho? That's what it seemed like at least
Still have the Milltek, so many punkasses keep backing out last minute. Ill give it to you for a good deal.
__________________
The BatWagon
'99 2L BAT A4
03-14-2011, 12:40 PM
Level up: 52%, 96 Points needed |
My '01 always said 'push clutch to start' whenever I had the car on but not running. Iirc, tips should say 'push brake to start' as well. I sawa thread on AZ where dude had a tip but got the 'push clutch to start' message, if that was the case then you'd want to be worried, but from what I've seen your car should say that before start up.
__________________
01.5 Brilliant Black S4 avant - JFonz 2+ / Piggies+SSAC / X34 intake / ST coils / Podi Stepper / Samcos / 007s / A8 flat fives / Thor skid plate
03-14-2011, 12:43 PM
Tech Slut
Quote:
Thats true, however, it still doesnt explain why he is just getting it now, unless he just never noticed it.
__________________
The BatWagon
'99 2L BAT A4
Tags
28, 98, a4, a6, audi, automatic, clutch, compression, pedal, press, pressed, push, start, startaudi, starts  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
