rear end moves side to side while driving
I drive a 1998 Audi A4 Quattro and it seems as though my car is shifting from side to side while driving and I cant figure out what is the problem. This happens when I hit a bump while driving and the car will quickly jerk to either side in the rear. Also, while driving in the snow the car will sway from left to right, a small tail whip from side to side as if the rear tires were spinning at different intervals. I recently had both of my rear tire bearing done, can the new bearing be the problem? It think the car drives more strait under conditions of the cause while i give it more gas.
There is no play in the rear wheels. There is some play in the right front wheel, up and down play, because one of the metal rod component is moving. Must have hit something can't remember what . I wonder if the problem in the front is causing the movement in the rear?
Also, I think I may have a problem with the right rear suspension strut because it makes a bunch of noise when going in a pothole etc. Will check out the strut first. Anyone have any ideas on how to test the suspension strut?
