shifter problem or tranny problem?
Old 03-10-2012, 11:14 AM
Christopher Nemitz's Avatar
Default shifter problem or tranny problem?
My car is usually hard to put into first and third gear. When I am completely stopped it goes into first easy, if I am rolling at all it is hard. When I go to shift into third it also seems hard and sometimes I get feedback from the shifter, like I miss shifted, but just a little. My clutch is bad and slips in 3-5 if I give it enough pedal to boost at all. Any advice guys? Thanks!
Old 03-10-2012, 11:32 AM
M5S5's Avatar
Tech Certified
It's possible the pressure plate is starting to go bad , especially if you are getting slipage.
Old 03-10-2012, 12:09 PM
Even with my clutch pedal to the floor it does this, my clutch disengages way at the top, I only have to push 1/2" to fully disengage the clutch/pressure plate.
Old 03-12-2012, 07:57 PM
rodhotter's Avatar
redline MT-90 fluid does wonders for shifting but will not help your needed clutch job
Old 03-12-2012, 09:02 PM
redline380's Avatar
Legal Moderator
could either be 1. you need to adjust your clutch, like it isnt fully engaging, or 2. your synchros are bad and you need a new clutch. Im going for option two because no one with a b5 has good synchros any more. Although first gear is supposed to be synchronized, it really is only needed if you are completely stopped. i cant get mine into first even going 2mph. and im sure youre synchros are getting bad. as stated changing fluid may help, but it isnt a fix. as for your clutch slipping, you need a new one.
jeddarr
09-12-2010 06:31 PM
99A6er
03-23-2009 08:43 PM
kapil403
09-10-2006 07:30 PM
KentStateAudiS4orce
07-22-2006 11:03 PM
lunite
03-15-2005 05:26 PM
Quick Reply: shifter problem or tranny problem?
