Transmission Fluid fill - overfill risk
Old 12-13-2010, 08:18 AM
vtraudt's Avatar
Default Transmission Fluid fill - overfill risk
My trans is slipping from 2nd on. I tried the fill up procedure with right trans temp twice. To rule out low trans fluid as a cause, I would like to 'overfill'.
We have a nice cold day today, so I could get the engine running, shift through gears (10 sec each), raise car, get fill plug out, insert the fill hose, and pump ATF in until if overflows. All with a much lower (say 10-20 deg C rather than 35-45 deg C as recommended). I assume this would cause a higher fill level.
What if any are the risks involved in do so?
If it solves my problem, I would know that it has to do with the ATF level (or pickup tube or filter or else).
If it does NOT impact the problem, I would just get the car to 35 deg C and take the fill plug out and let the extra fluid drain.
Input, please!
Robin Schroeder
03-04-2011 03:33 PM
aamele8
02-13-2011 01:47 PM
fromerich
05-09-2010 08:48 AM
mach1usmc
09-03-2007 12:01 PM
cary12
12-04-2006 05:49 PM
Quick Reply: Transmission Fluid fill - overfill risk
