Rear Driver's side window issues.
Old 09-13-2009, 11:20 PM
kayakman13's Avatar
Default Rear Driver's side window issues.
Here's a video, excuse the lame narration.
Pretty much when I pull up and hold the button/lever whatever you wanna call it for the rear window, it goes up to a point, stops like its sensed resistance (the window is programmed for pinch protection I believe) and then goes down. But, if I inch it up by pulling up the button in short bursts, it makes it to the top. When using the central locks from the outside (rolling up all windows with key) it goes up no prob.
Any help/ideas?
Old 09-15-2009, 02:36 AM
kayakman13's Avatar
jello!?
Old 09-15-2009, 04:07 PM
CCA4's Avatar
Could be a bad regulator? Mine does the same thing from time to time, although it also does the same when i use the key to roll the windows up
Old 09-15-2009, 06:02 PM
ImTheDevil's Avatar
You could always unhook the battery for awhile. When you reconnect it, you'll have to reprogram your one-touch windows. Maybe by blanking them out and resetting them, you'll clear the issue. It's easy enough to try it. Be sure you have your radio code though.
PeterCS
07-29-2013 08:36 AM
ed1404
08-09-2011 04:10 PM
boojiray
01-21-2008 08:25 AM
KiserRN1981
04-07-2007 07:06 PM
JohnnyBravoA4
07-25-2006 02:50 AM
Quick Reply: Rear Driver's side window issues.
