VAG-TACHO-USB drivers - AudiForums.com
Reply
Thread Tools Search this Thread
Old 04-29-2008, 06:30 PM
K1196A's Avatar
Default VAG-TACHO-USB drivers
Guys I bought a cable for vag-com off ebay from chiltonsonedemand and they sent me a vag-tacho-usb cable instead. i have the vag-tacho software, but can't get it to recognize the dongle.
anybody get it to work?
Old 04-29-2008, 06:38 PM
chaos92287's Avatar
Default RE: VAG-TACHO-USB drivers
wtf is vag tacho?
if your talking about getting the software to recognize the usb port as a com port you have to use the device manager and switchthe usb to an unused com port
Old 04-29-2008, 07:21 PM
K1196A's Avatar
odometer.
got it to run on a 32 bit system (i have vista 64). didn't change anything, just tested it.
Old 04-30-2008, 10:50 AM
Redrum1's Avatar
I know some people have had problems with these cables sold on Ebay and no matter what they tried they couldn't get them to work. There is one seller named alpha-bid on there and his cables work with Vag Com just fine.
Old 04-30-2008, 10:52 AM
K1196A's Avatar
Quote:
ORIGINAL: Redrum1
Good -- i just ordered a vag-com cable from him on Saturday!
Old 04-30-2008, 11:13 AM
chaos92287's Avatar
thats the same guy i bought mine from. if you get the usb version your gona have to have a little bit of computer knowledge to get it to work right. if i could go back, i'd get the serial port version instead just to keep it simpler
Old 04-30-2008, 10:24 PM
I keep getting this stupid error everytime I try to vag my whip.... It's like " BLA BLA BLA 'memory could no be 'read'...Then there's two options to either"terminate" or "debug" both shut down the program... I'm using ross-tech.. Any ideas on this one?
Old 05-01-2008, 05:47 PM
K1196A's Avatar
well, hmmm! i had tested this app on my wife's laptop because she has XP on it and mine is vista and it worked fine first try. today i installed a virtual machine setup on my vista laptop and it wouldn't recognize the cable. i tried several things and it was a no go. i decided to plug it back into my wife's system to verify the driver install and then it wouldn't work there either. weird........
Old 05-01-2008, 06:08 PM
chaos92287's Avatar
so you tried it on hers and it worked, it wouldn't work with your vista, and then you tried it again on your wifes computer again and it didn't work?
did you plug it into the same usb drive as last time? when you plug it into a different usb port (like on mine, there are 2 right next to eachother) it will use a different COM port. so unless you use the same usb port, it will keep switching the COM port back to the default one
texas_pete- dont know on that one, whats the exact message its giving you? what does it say when you test the COM port?
Old 05-01-2008, 07:53 PM
K1196A's Avatar
correct. same port -- just flaky software/plug combo. don't know -- don't really need it anyway -- it just bugs me it's not working.
Reply
Thread Thread Starter Forum Replies Last Post
Audi A3 8l 97' VAG COM and VAG TACHO Kardiii Audi A3 1 03-12-2016 08:24 AM
Tacho Pro 2008 Plus auto611 Misc Items for Sale 0 08-07-2012 05:40 AM
Can VAG-Tacho or VAG-CAN Commander 5.1 retrieve SKC? afruss2007 Audi A6 0 11-03-2009 08:34 PM
Disconnecting Odometer, Speedo & Tacho liquidtuna Audi A6 3 03-12-2008 10:12 AM
Tacho pro zingo1 Computer & Fuel Systems 0 12-05-2006 07:28 PM
Tags
64, 64bit, alphabid, bit, cable, driver, drivers, install, tacho, tool, usb, vag, vagcom, vagtacho, vista
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
