Window Switch Replacement - AudiForums.com
Reply
Thread Tools Search this Thread
Old 02-16-2011, 10:39 PM
Default Window Switch Replacement
Hi, I'm new to the forums. I've been reading it for quite some time, even though I'm a relatively new Audi A4 owner. I really appreciate a lot of the threads that have helped me out with my new car! But I could not find one about a 2001 A4 where the window switch doesn't work well. My problem is that on the drivers side window switches, I can make the passenger window go down, but I can't make it go up. However, It works both ways on the passenger side switch, so I believe it is the switch in the master control (if I'm wrong please correct me). Now I have a new switch and I want to install it, but I don't want to break anything, so if someone could please tell me how to install it, that would be great. Thank you!
Old 02-17-2011, 09:24 AM
JoBuNY's Avatar
Follow the directions here to get your door panel off
http://www.audizine.com/forum/showth...gulator-How-To
once you get your door panel off you will have access to the underside of the door switches. From here you can swap the wiring on the switches to test and see if that switch is in fact bad OR you can release the entire switch panel and then swap in a replacement switch if you already know your driver side switch is in fact bad.
Old 02-17-2011, 11:00 AM
sweet thanks!
Reply
Thread Thread Starter Forum Replies Last Post
Window and Window Switch Issue Mr.Gerb1k Audi A6 5 09-28-2013 11:00 PM
Driver side power window switch replacement fowler12 Audi A4 15 07-20-2012 02:47 AM
Passenger window will go down but not up using the driver's window switch.....???? etran Audi A6 1 04-12-2011 12:22 PM
Headlamp Switch and Power Window Switch njscardino Want to Buy 0 09-25-2010 11:01 PM
dip switch/ Combination switch replacement?? Stevenw83 General Tech 1 08-23-2010 01:12 PM
Tags
01, 2001, a4, a8, audi, b5, change, diy, master, removal, replace, switch, switches, window, windows, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
