Help iPod OEM adapter
I need some help installing the OEM iPod adapter kit (8E0 051444) I picked up from the dealer.
I have the Symphony II radio out but the 20 pin connector is just strange. I have two cables with the kit, I'm using the harness that has a blue connector with 10 wires that needs to be installed into the OE black 20 pin connector by removing wires. I need to use a special Audi tool to remove the wires. Is this correct or have I missed something simple. Any links that show how to install the adapter. Thanks.........
Audi 2004 A4 3.0
Symphony II radio 6CD changer w/ XM SAT.
(no external CD changer)
Audi 2004 A4 3.0
Well I did switch the wires, push them out of the blue connector and plugged them into the 20 pin OE connector. Connected the iPod & saw the Audi logo and all is good, plays great, with 99 songs in each of 5 tracks. Also I found more help from two other sources if someone needs some info.
http://www.nsxjr.com/ted/TED_RNS_E.pdf
http://forums.audiworld.com/showthread.php?t=1921768
