Audi a4 b6 front turn signal wire harness problem. Help!!!
Ok so I have the b6 model and the left front turn signal does not blink.
I have changed the right side complete headlight with working turn signal to left side and shows same problem. The amber bulb lights up when I turn the lights on but does not flash when I put the turn signal on.
I have also replaced the hazard switch in the middle of my dash with no luck.
I have also found the wire in headlight connector and added power to it with a tested n the bulb lit up.
I think there has to be a problem with the wire harness.
FYI the rear and side blinkers work on the left side. Just not the front bulb in the headlight.
If you have a wire harness schematics or think of something else that might be it please let me know.
I think they have some recalls on this one.. But might want to check some of the Audi recalls here are some list of it.
I have the same issue (front left turn signal bulb is not blinking) on my 2002 A4. I bought another bulb, installed it, got in the car, and the bulb blinked properly. (I also physically saw the bulb blinking). So I shut the car down and went about my day.
Several hours later, I took the car out, got the OK signal on the dash...then made a left hand turn and got the dash failure display again..so I am back to where I was before, new bulb is not blinking.
Joe
Joe
