Battery was removed, now remote unlocker/locker won't work
Old 07-21-2010, 12:21 PM
adsquare's Avatar
Default Battery was removed, now remote unlocker/locker won't work
Does anyone have any ideas on how to fix this? Cottman didn't seem to know, and searching i couldn't find much. Help ASAP would be great
Old 07-21-2010, 12:59 PM
02A6Beau's Avatar
try locking/unlocking with the key and while it is still in the door, in a neutral position, press and hold the lock button until it locks
Old 07-21-2010, 01:51 PM
oki's Avatar
oki
oki is offline
I have seen a couple HOW TO's on this:
Use your Valet Key and turn the car to the ON position but don't start the car. Then use your 1st remote and hit any button just once (don't hold it). After your light blinks..then hit the lock or unlock and see if it works...if so, you are done.
Repeat the above for a 2nd remote...just hit any button twice and don't hold it, so the light blinks twice and then hit the unlock or lock and see it works....if so, you are done.
Any more remotes you have just increase the hit any button step by 1 to identify the remote as #3, #4, etc...
NOW THE ABOVE DIDN'T WORK FOR ME
What I did with my car....is to put the valet key in and start the car. Let it idle for 2 minutes. Remove the valet key and put the remote key in and start the car...let it idle for 2 minutes. Upon removing the remote key, I hit the lock button and it worked.
Did the same thing for my other remote keys and it worked perfectly.
Good luck
FOONOTYOU
12-05-2012 12:16 AM
partytime
B7 Models
06-05-2012 09:09 PM
partytime
06-05-2012 02:21 PM
MartinCieslak1
12-11-2009 02:30 PM
vivanov1
09-18-2007 12:11 PM
Quick Reply: Battery was removed, now remote unlocker/locker won't work
